The more I read the less I know. In Mike Davidson's book he states that exposed threads aren't generally a problem and that by removing material you lower the compression ratio. But to my way of thinking what good is having the ideal compression ratio and then you discover you have a detonation problem after installing the engine in the car. By the way, what would be the ideal compression ratio for a modified street engine? I'm around 8.2 to 1 I believe. While on the subject of plugs, he mentions that indexing the plugs might be worthwhile. I know the "go fast" overhead guys do this, would it be of any benefit for a flathead?Chuck a chamfering bit in your hand drill and do some "trial-and-error" chamfering of the theads in the combustion chamber. Check frequently with your sparkplugs to determine the required depth until you establish a pattern.
Re-calculated my compression ratio and is probably closer to 8 to 1. Milled the heads .020 and increased valve pocket depth to .445 ended up with 70cc in the head. Sure seems like it cost me a lot in compression. I've heard of people milling .050" but maybe they weren't Offy heads; at .020" am within .040" of piston edge hitting head. I'll be glad when your book gets here.Your C.R. is real close to optimum for regular gasoline. The "IDEAL" ratio will vary with several factors as outlined in my book.
The primary reason for indexing plugs is to achieve mechanical clearance.
