Exhaust manifold\heater
Tom Endy
Westminster
CA
Price
$75
Exhaust manifold for heater attachment. I do not have the top section, but the manifold itself is in excellent condition. The manufacturer is unknown. I bead blasted it with aluminum oxide, took all the rust and crud off of it. There are no cracks or other damage. One of the two mounting bolt holes at the top for the top section had a broken bolt in it. I drilled it out and it will need a heli-coil inserted or re-threaded for a larger size bolt.
I plan to paint it with heat resistant black paint to prevent it from rusting again, or I can leave it unpainted. This will be an excellent replacement for someone who has a heater\manifold set up for their car, but has a cracked manifold. $75 plus shipping.
Tom Endy 714-897-5861 tendy@socal.rr.com
