Re: exhaust manifold gasket - Gland Rings
I don't know if things have changed but years ago a friend used repro gland rings and the heat just curled them up and some ended up as rattles down in the muffler. I'm fortunate enough to be running original Ford NOS manifolds, gaskets, and gland rings so this arrangement will likely long outlive me.
The "restorer" must be smart enough to check the fit before assembling. 99% (or more) of original exhaust manifolds are warped in such a way that only 2-3 of the ports will still align with the block which makes glands unusable in the other ports. Additionally, When manifolds have been surfaced the counterbores for the gland rings are often too shallow to allow the manifold to seat against the gasket. The result at best is a lack of seal, and at worst is a broken ear or two on the manifold.
Take the time to be thorough and apply a little common sense and all will be fine. And no, don't use a sealant on the manifolds.
