jagnweiner
I need to replace the gasket between the driver's side exhaust manifold and the down pipe. In searching the vendors, I don't see anyone that sells just that gasket. However, I see Mac VP sells a set of 8 exhaust manifold gaskets. Is that because the gasket in question is the same as the ones between the manifold and the block? (i.e., 6 to go between the manifolds and block and 1 each side between the manifold and down pipe)
I don't mind ordering a set of 8 to get the one I need because the price is cheap; I just want to make sure I get the one I need.
