Tom Wesenberg
Has anyone seen a good picture of the position of the exhaust clamp as installed on the assembly line? Just wondering what the exact position should be? Thanks
Tom,
Here is an original photo of the right side of engine number A1151 that shows the position of the clamp.
I'd say you've got yours just about in the right position. Note that both nuts are on the visible side of the clamp.
Hope that helps.
Fordially,
Brad in Germany
Tom, AFTER you turn the clamp back again, check out the archive photo, Area 1-6 in the JS.![]()
Tom,....I know about the bracket, BUT what about the gas tank , the spark arm on the dist.,I thought the cut out should be on the side, water outlet LOOKS reinforced, and CHARLES REESE has that same intake manifold.
