Pete
Neat. How did you get 10:1? Lots of lift, lots of duration I assume. Running RPM? Really curious if you used babbitt or inserts. I assume full pressure. Thanks
I used a Dan Price head and welded up the combustion chamber as per his instructions, then machined it to look approximately like an Edelbrock V8 flathead chamber...Cam duration was 300 at running cl...Rpm was 6400 normally...Insert bearings with 90 lb full pressure..
Here is some of the details..This was part of the ad when I sold it..
"Model B flathead Engine:
Dan Price finned aluminum head. 10.4 to 1 compression.
BB crank (full pressure), R.E.M steel "H" beam rods, Ross forged
pistons, titanium valves and retainers(1.65 dia), bronze guides.
Block has 4 intake ports.
Radius lifter 5 bearing cam with .488 lift and bored camline with inserts,
Dan Price oil pump, Dan Price aluminum pan.
Roto-Faze distributor, Jacobs computer ignition, D&L finned side plate,
Hi-flow intake manifold, 2 modified Stromberg 48 carbs,
equal length headers with lakes plug, 18 lb. big block Chev. front damper,
D&L water pump with modern ceramic/carbon seal for street. (looks stock)
Electric water pump in race car.
Water manifold for equal water distribution.
Everything from the block back is set up to take a Chev. transmission
(T5,or Richmond 5 speed) but could use any transmission with
adaptor....Could also be put back to original model A or B. The back of the block
has not been modified.
11 lb alum. flywheel with alum. clutch.
168 hp on the dyno.
This engine is very streetable. Lopey idle at 800 rpm.
Gear drive starter (Chev).
Included is the top part of the 600 cfm Holley 4 barrel manifold that was on the engine when it
was on the dyno and in the race car.
Also included, intake manifold for 4 side draft carbs or injectors."
