The original Ford guides from 49 - 53 has a "solid" guide on the exhaust side - there was no place to put a seal. Also, as the exhaust is under positive pressure, you don't have the issue you have on the intake side where the vacuum pulls oil from the valley into the port.
Sealing: The carbon from combustion will "seal the guide" on the exhaust side anyway - so the seal won't accomplish anything.
And lastly, I like the solid exhaust guides as they do a better job of transferring heat from the exhaust valve into the cooling system (due to a larger contact surface area between the guide and the guide bore)..
I've been using RTV for the past 50 years on all my buills. Just put alittle around the bottom of the guide before you install it and slide it in. Another thing I do isKnurl the guides. I just use a tool on the intakes. I bought the tool about 50 years ago place the guide in a lathe or vice runthe tool thru the guide, blow it out all done. Yes thery make better systens, but this works
Gramps
Knurling DECREASES the area of the guide in contact with the block. This slows heat dissipation from the valve. A bad thing.
Copper plating INCREASES the contact area to the block and along with superior heat transfer properties speeds the heat transfer away from the valve. A good thing.
I don't Knurel the outside of the guide just the 341 hole in the middle, and copper plating cost money which is not necessary for a street engine.
G
