alexiskai
Awhile back I asked about spark plug connectors for use with a Winfield head. The Winfield relocates the plugs between the valves, rather than over the intake. This means that the 1 and 4 plugs are now too far away from the distributor for the stock connectors to bridge, and the 3 plug is uncomfortably close to the spark advance rod. After some trial and error, I came up with this solution. This uses Model T plug wire and terminals.
I think it came out pretty well, looks period and does the job. I did end up putting a bend in the spark control rod to move it farther away from the #3 plug, and I'm also going to wrap a little electrical tape around it just to be safe.
