Does this car have circuit breakers. A short in one of the systems may have started this if it is a breaker but I've had breakers that just gave out for no apparent reason before.
I do not have an amp meter wired ahead of the ignition switch, so that wasn't it.If you have an accessory Amp meter? That could be a source for problems you describe. Had one in my 55 years ago and it had heavy wires going to it. All power to the car ran through it and its connections. Just a thought - Bob
I remember once disconnecting the battery in a 51 Cadillac while the car was running. I did it only to try and switch batteries in it while running thinking I could get it to charge a weak battery. It shut down completely. I used to do it with cars that had alternators often back then because I didn't have a battery charger.
I was told by our local GM dealer here that battery life is expected to be 3 years now. That has been proven to be correct in my RV. Whats going on??
Probably because China may be supplying batteries now too.
Sal
