It's a champion spark plug in a special case. Sleeve allows air from engine compression to go to side pipe, which I believe would have a hose attached to fill tires up. So yes I guess it is a tire pump.
They were fairly common in the mid to late 50's in North Texas.....I was just a nipper but I remember my uncle raising the hood on his old international truck and airing up tires.
Thanks for the info. I saw the plug would not fit a T, but figured this forum would have the best, most knowledgeable participants to answer the question.
dp is correct. More expensive units screw in in place of the spark plug and have a piston that is actuated by the combustion chamber mixture to pump fresh air.
I agree with Layden and dp. The unit that I had years ago was similar to this one, but did not have any fuel mixture injected into the tire. It was like a small piston that used outside air. And yes, Royce, I figured it would be kind of tough to have a flame inside the tire, dah.
they were sold by sears as a craftsman product in the mid sixties with different adapters for most of the sparkplug sizes. I have one I carry in my A and I used one of the adapters that you can buy to put 14 mm plugs in your A. Ed.
My dad had one that he used to blow up air mattresses when we went camping. I don't know where he got it, but my guess would be Sears. That was the Wal-Mart of the forties.
