I have a small heated ultrasonic machine. I wander how it would work with a little heat and vibration?
This is interesting. Does white vinegar dissolve the rust, as apparently Evapo-Rust does, or merely work it loose and create flakes to clog the radiator? I just ran vinegar through my coupe, and the water is now running clear, but I have an overheating problem.
got any before and after pics. I also would like to know if it would work well in a gas tank. did the electrolicis on my tank with a 55 gallon drum it took the paint and light rust off the out side I left it in for a week I will try it again next week to see if any more comes off.
The rust is not loosened. It is dissolved. The solution turns black and the rust disappears. I don't see why it wouldn't work on a gas tank. It would leave you with clean steel and wouldn't affect any coatings.
Hey Joe,
Hm, you may have answered your own question , by your investigation/questions and answers directly to evaporust ! This stuff ain't CHEAP,eh ! This presents an opportunity ..maybe.. for some to make a buck. Further investigation is needed. Try a small amount on a small rusty part and see what. I have used this product enough to know what/how it works. So, I would have an idea if this is repackaged real mc coy stuff or snake oil. Let us know. Curious, why did you buy it this way and how found ? If it is real product, and less expensive, we would appreciate knowing, thanks.
BTW..some are saying, well..left it in for few days. NOPE, no where near enough time if bad rust, like in a block. And, best to 'ROD' out block first to get all the chunks possible. Then, IMO, works quicker/better. Great results in my opinion and useage !
