if the tires are around 100. each, they will never be radial.
radials fetch a good bit more. aside from the radials performing better, Im not a fan of the look.
The excelsiors I bought have a very sturdy sidewall and are fine for the price. how long they last I dont know, but I dont drive as much as I would like anyway.
If youre doing major touring, then I would start looking at the european classics or better.
Radials fetch a good bit more. aside from the radials performing better, Im not a fan of the look.
????? Maybe you haven't seen the "Model A" radials...They are the same size as the bias ply tires and look pretty much like any other tire on a Model A but the handling is very much improved. My main driver has radials but the other 3 have biased plys for now but when they need tires they will get radials for sure.Not sure what you don't like about the look of Radial tires. But to each his own.
because they look like a hot rod and I prefer the original "skinnys"
dont care for 16s on my model As either, but I know half of the people on the barn do.
Because they look like a hot rod and I prefer the original "skinnys"
Dont care for 16s on my model As either, but I know half of the people on the barn do.
Hmmm, here's a picture of my "Hot Rad", 4.75-5.00Rx19 American Classic tires.
same colours as mine... what are they called?
ok, so I mounted 2 last night. first one nearly killed me. took an hour and was the toughest tire I ever mounted. the sidewalls are pretty thick.
2nd one I used dawn soap on the beads and had it on in 10 minutes.
went to fill them up and first one I pinched the tube! so back at it today!
