fiddlybits
A couple questions please. How long does it take to process a tankful ? Why does your car need this process but other Model A's run fine without refining the gasoline pumped into the car at the gas station.
Can you only do five gallon trips so you can then get home for a refill ?
Wayne
It took me about an hour and a half to set uo, separate 20 gallons and clean up. The actual separation is rather fast (and fun to watch) but I usually wait 15 minutes per bucket for everything to settle.
I started doing this year's ago for old motorcycles and mostly do it now for my 2 cycle tools.
I hadn't thought about it for the A until I the same symptoms that some of the bikes had.
The A had 1600 miles of pump gas before this tank so why it had a snit I do not know. I have run 2 tanks of un-ethanol-ed gas without a skip but put ethanol 10% in last night to see if the problem returns.
