Allen, Thanks for forwarding to StarTron for a reply! I hope you're making a ton of money (Model A's are a $ pit). Nothing personal, but I am not yet convinced.
I'll make a few comments based on Matt's reply to you:
"Dear Allen,
I am impressed. I had one of our tech people answer below. While you seem to question our product, my question is have you really tried the product ? or are you just doing to be a cynic ?????? Suggestion, take the worst running lawn mower or engine you have. Start engine and while running pour some Startron in tank. Watch it run smother and more powerful in minutes."
You'll get the same result from many other naptha based fuel additives. I cannot attribute this to any secret, proprietary enzyme. What Matt proposes is a wildly subjective, unscientific, uncontrolled experiment that does not relate to isolating the effect of "Enzyme" in StarTron on phase separated fuel mixes.
"Dear Unknown Biochemist: What? No SDS-PAGE with a silver stain? C'mon.... use the good stuff!"
Had I known your "enzyme" existed at less than 0.000001%, then yes, I could have run electrophoresis to ID the molecular weight in KD's (kilodaltons for the casual readers) against a few known markers run in adjacent lanes. (How I hate acrylamide dust! Pour your own jells???) Silver stain? Maybe to see if anything is there on an initial jel, but that's so yesterday. Once you find something, you want to make it quantitative. Staining with AgNO3 gives a rather primative indication in that regard.
However, I don't think you have a lot of knowledge about the interface between biochemistry and petroleum chemistry.
True. petrochem is not my end of the organics spectrum.
As you noted, the level is extremely small. We just want to "nudge" a few electrons here and there, change some surface tension, make some very minor changes in fuel chemistry.
WOW! Sounds like the battle cry of a homeopath- the more you dilute it the better it works! So, if you only want to nudge a few electrons, you are depending on your "enzyme" to break down at some point, as a single molecule will catalyze endlessly. Lowering the dilution will only extend the time frame to interact with every fuel cluster that fits the substrate. Gee, if you dilute it 10 to the minus 24th, only five bottles in a dozen have a chance of containing even a single molecule. I guess I got one of the other seven?
You will have to understand that we can't share with you any more than that. This is a proprietary technology in a very competitive industry.
Matt, Kudos for sharing as much as you did. Of course, if any foole (like me) actually saw value in your claimed proprietary secret ingredient (enzyme?) it would be a straightforward matter to start by cutting out isolated constituents of your mix from the gel, determining the A.A. sequence, then running over to RasMol (peanut gallery- look it up) and modeling it for all to see and produce. I might have to do a bit of x-ray diffraction crystallography to get the final conformation physical structure correct (peanut gallery- the active shape of the molecule) but it is routine and straightforward.
If there was any real market share visible in StarTron, irrespective of proven functionality, the above WILL happen, and any claims of patent or "proprietary" will be out the window by flipping a non-essential R- group or two. I hope it doesn't get too competitive for you!
