19Fordy
An earlier thread motivated me to find the tool I made in 1978 to remove the old and install the new door handles and Escutcheon pins. You locate it around the handle using the slots. Then you lean against it with your body/legs and the OD of the PVC pushes against the outer flange of the Escutcheon plate pushing it inward so as to get access to the little pin with a pin punch and a hammer. The brown burn marks on the OVC are from the propane torch I used to soften the PVC for easy bending to size to fit the Escutcheon plate. The black electrical tape protects the handle and the Escutcheon. Interior door panel is LB. Works great. Perhaps this will help someone.
