Tom Wesenberg
I thought the engine was out of the car. That's the first thing I would do. It'll be so much easier in the long run.
Tom, I'm going to try the cable trick and blow gun. If I do decide to pull the engine out, will this bolt up to a regular engine stand? I've got one but was thinking to much stress on bellhousing area. I'd sure like to turn this over to get all the junk out of passages. I've got to buy a new radiator and I don't want to plug it up.
You'll find you can't remove them out the bottom...
It's a little cooler today so thought I'd get back to removing pistons. Got one out! I'm thinking that the carbon build up on the skirt of the piston is stopping it from coming out. I never knew these had a relief cut in them.
Shudda quoted ya, man! Good ale in New Mexico. Niko is an artist. Good hops, etc.It's a little cooler today so thought I'd get back to removing pistons. Got one out! I'm thinking that the carbon build up on the skirt of the piston is stopping it from coming out. I never knew these had a relief cut in them.
Didn't you say you used a hammer and brass punch to remove #4 piston?Got some free time to work on the wagon. Took the pistons, oil pan, dipper tray, valve chamber cover and drain tube to work and stuck them in a part washer. I wish I had one of these at home! Parts cleaned up real nice. Some of the paint came off so nothing but clean metal now. Removed the intake and exhaust manifold and bead blasted the intake manifold to prep for paint. I disassembled the carb and soaked it in Evaporust, wow this stuff does work, and also ran it in a ultrasonic cleaner that I picked up at Harbor Freight. I was suprised it worked real well. Still has some rust and varnish build up in float bowel. I'm thinking of bead blasting it but I'm not sure yet. Next I'm going to clean the carbon build up on the pistons and rings. I'm think of blasting them with walnut shells and see what I can remove. Well thought I'd give an update and maybe post some pics later. I forgot to take pictures of the carb before cleaning started.
