First post, would just like to say hello to everyone,
So my issues is with a 12V 1950 Ford F-1, she's been sitting for almost two year and I went to finally go start her up. I cleaned the battery contacts, charged the battery overnight and hooked it up, pressed the start button without the ignition key turned to get fuel in the line, the engine turned over several times without any issues to prime the fuel line. Tapped the carb, sprayed some starting fluid in, turned the key and pushed the start button and she started up almost immediately. She ran for a couple of seconds and then stalled, not bad for sitting for almost two years.
So I put some more starting fluid in her, pressed the start button and I get just a clicking noise from the solenoid....... Tried a couple more times, recharged the battery and still get a clicking noise. I cleaned all the contacts on the battery, the ground, and the solenoid, gave the started and the solenoid a couple of taps and still nothing but a clicking noise from the solenoid. I do have a battery disconnect on the negative side of the battery and I disconnected that and just hooked the ground wire right to the battery, tired that and it did like a half turn and then just a clicking noise.
I'm out of ideas, I'm thinking either bad solenoid or bad starter, any ideas?
Thank you,
Craig
Thank you,
Craig
