petehoovie
I can see now why you want to retain that ignition setup you have....
Great looking engine. Should perform well. The coils - did you put covers on them or did they come with the checkered colors?
Are you using solid, stranded wire, core spark plug wire or something else like resistor?
Did it get fixed? What was the problem?
I like the appearance of the coil covers and your crew chief is commended for her work. What would happen if you remove the covers and use your heat gun on the coils when the engine is at 200 degs? Ie, are the covers the cause of your problem? Heat transfer from the coils blocked by the covers? Try it and see what happens. You might also keep in mind that the engine is new and needs breaking in and I think it will run hotter during the break in period - mine did with a fan. Now runs 170 without a fan, but keep moving. But I am not in a city either. And I am using stock mains in 97s and 71 pvs. I had the same problems that you are experiencing. I had been running 43 mains and 65 pvs.
Lousy performance - ran lean.
