Henry's Lady's Man
I removed one shim from my front main, and one from my rear main. They were foil-thin, and measured .001 each. All three mains are now .0015; I used assembly lube.
The engine turns by hand, but with about 20 lbs of arm pressure. The rods are not connected yet. Is this too tight to start? I'd hate to get the engine back in the car and find that the starter can't handle it.I would suspect that the ring gear will gear it down enough, but I just don't know. This is my first rebuild.
