A few months ago the blow-by in my '48 59Y (Mercury crank, dual strombergs, mild cam) got to be too much -- causing a big mess.
#7 was running 70 PSI and all the others 120. Pulled #7 to find skirt scuffing well below the oil ring. Decided to look at the rest of 'em.
All the rest had scuffing, too. The top compression ring on #1 was broken in half(!).
Visual inspection revealed no problems with the cylinder walls. Repeated snap gauge measurements reveal minimal wear (each measures between 3.312 and 3.313) -- the block seems to be in really good shape. Crank is fine, too.
Piston scuffing is not noticeable to the touch, and there is no taper to any piston. All pistons measure and look good otherwise.
Washout/detonation seem to be the causes, but a long time ago it suffered intermittent loss of oil pressure, when the oil plug fell out(!).
Gonna carefully re-check everything, hoping for just good honing and new rings
