Woodie1
I have just replaced the timing gear on our TUDOR.I think this is the 3rd time in the 42 years I've had it. When I originally rebuilt the engine I used new standard size crank & cam gears. The new timing gear I used today was the laminated standard size. When I started the engine, it sounded like a tractor & I could sense a lot of missing at the carb throat. Before I removed the old cam gear I hand cranked the engine until the 2 timing marks lined up. It took me about 5 tries to get the cam gear to line up with the locating pins when I installed the gear. My curiosity now is I'm wondering if the cam gear may have been marked in the wrong location. How can you tell if it's marked in the right location? I never thought to match it up with the old gear. It has very little power at this time.
