jrvariel48
Seems like things are moving forward. That's good. Even if it doesn't work.
I agree Tinker, I think I'm on the right track
Well, it sure does seem to be a lot better than before - that is great news. I would beat it up on the highway a bit (try to pull a hill or someplace where you can put some load on it) and see how the temps register.
Seems the issues might be related to an air-flow restriction on the shroud.
If it keeps the motor temp where I need it, I'll be happy. Knowing the size and what will fit, a Spal could always be installed.Removing the fan shroud helped the air get out and your temperature dropped by 15 to 25 degrees bringing you ~15 degrees below your upper bound target. You're reporting a radiator temperature drop of 40 degrees. Keep testing.
Recommendations
The fan is mounted close to the top header. It should as high as possible to maximize heat exchange.
It is right under the top tank
- The lower panel should be added. ford38v8 and Rich B mentioned the louvers but I would add most of pan is it is solid and it does direct airflow to the core. There should be no downside. You could tape over the louvers temporarily to see if a solid pan helps.
I added the grille and lower pan today for testing.
- Greater cfm will help at the lower driving speeds and idle. You bought a flex-a-lite and had success but I still believe SPAL provides the best performance available.
Does anyone agree that ethylene glycol may help in this situation?
I still have a 5 gallon bucket of 40% ethylene glycol and 60% distilled water
The first thing to know in this situation is: When the coolant level in the radiator is checked after the engine has cooled,is the radiator completely full to the cap? At that time is there still some liquid in the expansion tank as well? If so, your tank is doing its job and you needn't worry. If you were losing coolant you'd soon empty the tank and the radiator wouldn't be completely full to the cap after cooling off.
The recommended tank size seems large to me. In my experience the required size can be quite a bit less.
Terry
Ah, I understand. As long as the core is covered any air should stay in the top tank above the coolant, and not cause trouble or affect the cooling. However, that catch can shouldn't be empty. It has to either have a leak of some kind or be filling and overflowing the catch can while driving to do that. Maybe a temporary larger can would be a good test. It can be mounted anywhere there's room.
I personally don’t believe that’s how I want one of my engines. Too hot on freeway. Your engine could drive cross country but not at that temp. On verge of too hot. No room for 100+* ambient. Or trash on grille. 78* ambient temp I wouldn’t want over 180-190* highway and driving around town with room for stop n go traffic
