2935ford
Just rebuilt my engine with insert bearings on mains and rods. Nothing else was done. Replaced everything back to where it came from. Engine runs quiet and smooth. Timing is fine. Drives well.
Took an IR reading after a good run. Top front head reads 210F and bottom rear 157F,
Rad top front 191F and bottom 170F.
Prior to this I was only using my Moto Meter as a guide.
It never got much past the bottom "Summer Run" line.
It now registers below this line and rises when engine is shut off which I understand is normal.
I have not run it up a long hill.
I do not have a temp gauge and by these readings I do not believe I need to be concerned. So I will continue to use the Moto Meter as my guide.
