47 COE
Hi everyone,
I've been trying to diagnose an issue that seems to be like a rabbit hole.
1947 Flathead 59AB
Stock
The engine will start perfect when cool or first start. But once it starts warming up to about 150 it starts to sputter and stumble. Seems to be miss firing. During this time huge power loss and will not idle off the gas pedal.
I've been searching the forums and have done the following.
Replaced spark plugs and wires
Replaced fuel pump
Replaced coil
Had distributer adjusted and replaced points
Carburetor rebuilt
Replaced vacuum line from distributer
Replaced cap/rotor coil
Verified compression
Changed gas
As I've replaced things little by little the engine seems to last longer until stumbling.
Any suggestions would be appreciated.
1947 Flathead 59AB
Stock
Replaced fuel pump
Replaced coil
Carburetor rebuilt
Changed gas
