Railcarmover
Build your own side mount and save a bundle.
ran mine up in a jiffy
I don't want to hijack this thread, but I use a Stipe type engine stand bracket, and I have a B engine with a Miller head. I am concerned that the weight of this engine (I want to avoid pulling the head) will be too heavy for this engine stand. I have visions of breaking off the pan flange. I need to redo the Burtz seal I have on the rear of the crankshaft, and I want to disassemble as little of the engine as possible. I think I need to polish the area where the slinger was a lot better or at least make sure that the drain back tube has nothing blocking the flow. Am I too squeamish about doing damage to the engine? I have over 10K in this engine, but the leak is really bothering me.
Purdy,I've got a Harbor freight engine stand and it can be connected to the rear of the engine . I use the engine stand adapter pictured in post number 6 that connects to the side water inlet . It works well and the engine can easily turned upside down .
Purdy,
I remember you traveled a LOOOONG way to a machine shop. Glad you have a Harbor Freight Store, near you.
I HATE folks that criticise them!!! Look at their website, they have more stuff than you can wave a stick at!
Bill W.
You have to take the rest of the pan bolts out.CarlG: how are you going to remove the oil pan after you mount the engine on the stand using the side mount adapter?
Engine is sitting in a corner, behind some stuff so hard to get a picture but this shows how I mounted it. Works fine for me. Its just the cheap Harbor Freight stand.Eagle, what stand is this?
