Where do you find the casters for ones like Jerry showed? I have checked at Harbor Freight, Home Depot and Lowe's, but for casters able to hold 500lbs or more, you have to shell out $8-$10 a piece...![]()
Are you putting the engine stand on one caster? Four casters rated at 250 lbs each could support a 1000 lbs engine. A complete A engine weights in around 500 lbs, so you should be fine with just about any caster you find.
