engine stalls
ralph j lawrie
on 31 slantwindow car stalls as if out of fuel after 1 mile, have changed several carbs, new gasline new shut off valves, new fuel gage and tank has been clean, as soon as i loosen gas line at carb engine will run for another mile. Thanks Ralph
I have had a similar problem recently, car would run fine, then die, like I had turned the fuel off.It would then start up fine and run perfectly. After checking everything possible, I took the glass filter bowl off and blew through it, and it was restricted, turned out it was the small rubber sleeve on the micro filter I had fitted within the bowl it was moving up and closing off the fuel flow. I took it off and no problem since.
Had the same problem as Bick with a micro filter that fits in the glass fuel bowl !!!!!
more JUNK to stay away frrom
John Cochran
