Rocketdog1
Hey all-
Need a little help on this one. '31 SW, stock engine. Did a few things to the engine today (exhaust manifold w/gasket, cap/rotor) and double checked the timing. She starts right up and seems to run pretty smooth (much quieter as well with the new manifold gasket!). The timing appears to be about 0 deg. at idle with the lever all of the way up - about 2/3 down and I'm 20+ degrees advanced - so I'm pretty sure I could get 30+ degrees if I wanted to. All verified by timing light.
The problem is that the darn thing has started smoking quite a bit. It's a blue-ish smoke, like she's running way too rich - or burning a little oil. GAV setting about 1/4 to 1/2 open with the engine warmed up. Doesn't seem to matter what I tweak or fiddle with, the smoke won't go away completely.
I don't remember it doing this the last time we went for a drive, so I'm puzzled.
I don't really want to tear things completely apart, but I guess I will if I have to. If you need further information, ask away.
Thanks in advance for any insight.
