old guy rich
Hi guys, can someone tell me what size engine this vin number indicates, B7NG127823. 57 Ford custom 300. Thank you. old guy
In '57 the engine code letter B is for the 272 Y-block V8.
Also indicated by the prefix letters ECG in the engine block casting number.
In '57 the engine code letter B is for the 272 Y-block V8 with a 2bbl carb.
You are correct. I accidentally overlooked that.Very good info Dennis,
One slight error in the picture of the engine code listings.
It says for code C it was a 292 4V. The 292 in '57 was a 2V.
Sal
All Y blocks look pretty much the same externally, so check casting numbers on block and heads to be sure of what you have.
You are correct. I accidentally overlooked that.![]()
... unless you know the history of the car from day one, don't assume that the engine in it matches the serial number plate. All Y blocks look pretty much the same externally, so check casting numbers on block and heads to be sure of what you have.
The number of original Y-block engines that have been swapped out for another (of questionable origin) is likely much higher than most folks would think. Don't assume...... If you want to be 100% sure of what you actually have and intend to rebuild/modify is to put it on a forensics table.
I remember way back in another life (almost), I worked Ford Parts at a dealership in the metro Detroit area.
Was WOODWARD AVENUE hot then?
Yes, both Woodward and Telegraph Rds. And long before the Dream Cruise.
