I have thought these would be an improvement...
https://www.nurex.com/automatic-spark-timing-system-mechanical-advance-12176
You have to look at them and check clearance,if they fail and get spun in the rod or block the crankshaft will be damaged along with the bore( block or rod) you can’t just replace insert.
With babbitt if you shut it down at first knocking most likely it’s just the babbitt.
What bearing "maintenance" does one do on an insert bearing motor?
Has anyone ever opened up their post 1936 (year flatheads got inserts) and checked and adjusted bearing clearances?
I've assembled an 8BA flathead and there was no adjustment mechanism. Why would you adjust insert bearings on a Model A?
Do people leave shims in on an insert bearing modification?
Does the crank wear faster on a Model A?
IIRC, Ford subjected each journal (proper name for the moving part) to a "roller high stress" which subjected the surface to "surface tension." As you say this thin "work hardened" layer is probably totally removed by 0.020 grinding.▸Yes, Model-A crankshafts tend to be softer once the hardening has been ground through. I grind Model-A crankshafts in-house, and I can generally tell by the sparks when I have ground below the hard surfacing. Generally this factory hardening only penetrated 0.015" - 0.020" on each pin, -so generally speaking, if you have a stock A crankshaft that is ground .020, .030 or .040 undersized, yes it likely does wear faster.
Many people have the misconception that if they have a Model-A block professionally converted to insert shells, then they can replace them if they become faulty or have worn out. In my post above, the definition of the term "maintenance" should include routine inspection of, checking clearance of, or replacement of.
I'm going to answer your questions as you have them listed....
▸I have a '32 Coupe that has an late '36 LB engine in it. Yes we/I have done "bearing maintenance" on it at around 40k miles after a rebuild which included removing the oil pan and checking clearances on each main & rod bearing. This is generally considered prudent when someone has a valuable or something that would be considered a difficult piece to replace.
▸Great question, ...but I am unsure why you are asking this as it appears YOU are the one implying someone is actually adjusting the insert bearing clearance(s). I don't believe anyone else used the term 'adjusting' in their responses above. Maybe I am wrong??
Well then I suppose that we're arguing semantics. When I hear maintenance, to me that implies actually maintaining something, not checking. If I check something and it's good, I don't do maintenance.
Checking and maintenance are two different things to most people.
Has anyone opened any of their cars in the past 70 years and checked bearing clearances? Is that in any of the Ford shop manuals?
Has anyone opened up a 1955+ year car, with insert bearings and checked the clearances as a regular "maintenance" item?
I cannot answer that question for you. This is a Ford Model-A Forum and this thread topic really has nothing to do with a 1955+ vehicle.
Is there a manual of a post 1955 year car that says at xxx,xxx miles you drop the pan and plastigauge your bearings?
Again, I cannot answer that question for you. As I stated above, this is a Ford Model-A Forum and discussing a 1955+ vehicle's Manual is off-topic.
I'm not talking about a babbitted Model A engine which the manuals are written to check bearing clearances.
I'm being argumentative because people are saying things that don't make sense and are being taken as gospel.
If you feel this way, why don't you send a PM to each person you feel has said something that did not make sense to you and ask them to explain it to you. Then if you disagree (-definitely your prerogative) take a moment to explain why you disagree and offer evidence to corroborate your opinion.
If there are reasons(Model A cranks wear faster with inserts, most insert jobs are not done correctly, etc) then I can see a point. But I don't think most people are opening up their Honda Civics and checking clearances, or their 8BA flatheads either.
I am unaware that anyone has been discussing Honda Civic or 8BA Flathead. Again, this is a Ford Model-A Forum and this topic has only been discussing Ford Model-A engines.
And to be even more argumentative, at the Miriam-Webster website, the definitions of maintenance and also maintain do not have the word check anywhere in them.
1 : to keep in an existing state (as of repair, efficiency, or validity) : preserve from failure or decline maintain machinery
I do admit that I misspoke and stated it was from Webster. I simply used Google to define Maintenance and it referred me to the word Maintain. I have attached a picture the definition that Google referred me to below. It does mention the work checking.
The bottom line in this is, as a professional in this hobby for nearly 3 decades now, I have seen firsthand how opinions vary on what 'Maintenance' on a Model-A is. As I mentioned above about checking oil or coolant levels, some hobbyists do this as their routine maintenance whereas others choose to wait until they see steam to add water, -or they wait until they hear a knocking noise before they add engine oil. The same mindset applies to tire pressures, brake adjustment, lube levels, etc. Therefore please continue do whatever works for you.
Well it was just a matter of time, glad I had my popcorn ready.
Brent, while I admire your dedication to the restoration of the mode A, I will respectfully say that I believe you may have a slightly different perspective concerning owning a model A than probably most on this forum. I think the majority here just wants to enjoy their cars and present them as they are, nearly 100 year old vehicles that they can drive and share with others without having spent $xx,xxx to restore. I park mine in the Walmart parking lot and don't worry much about it.Just my opinion
Often times misinformation is spread using the 'excuse' that they want to drive or tour with their Model-A, and to do that it must have all these modifications.
Not because I worry about being embarrassed (gave up on that years ago), but because of practicality. I am building my '30 Town Sedan into a touring car with 12V electrical with alternator. We've had club members have 6V components fail on the road with no commercial recourse (as I found out last summer when I blew both of my 6V headlamp bubs). 6V electrical components, including batteries, are simply not available at the NAPA in whatever small town you might be passing through.I think a large amount of "you need this for touring" comes from folks being afraid that, if a certain component did malfunction on a tour, they wouldn't be able to fix it – maybe because it's impractical to repair, maybe because they don't know how to troubleshoot it.... maybe because it doesn't work correctly now and they're just living with it. Better to replace it with something that doesn't necessarily perform differently, but at least it won't embarrass them in front of the guys.
