Here's the back story....It ran great when I parked, it next time I tried to start it after a week or so it wouldn't run. I had an electronic ignition on it that seemed to have stopped working ,no spark. After much troubleshooting I couldn't find why no spark or power to the coil. I removed the components and sent them back to be checked, they were returned saying everything was working fine. I then reinstalled everything but still no spark. to see if it was a bad system I remove the electronic components and reinstalled the point system, set the points, timed it and it started right up but now has this running problem. so, it won't run with the electronic system but will with the old point setup but now it runs rough. Yes It's cold here in Maine, thank goodness for a heated garage. good thing it's not touring weather yet, Maybe by then I will have found and fixed it.
