engine remove 1948 flathead
benp
Can you remove engine and trans together or seperate .is there a pan that covers the clutch does that need to come off before removing engine? 1948 flathead :
I removed the engine in 1947, Things I would do different remove the battery holder, and medal piece in front of radiator. I do think you can take both at same time. Someone will chime in.
We put the engine/trans combo back in my '47 convertible as a unit. It wasn't too difficult at all, a little maneuvering and wiggling got it done. We removed it as a unit also.
Hood, radiator and upper deflector that sits in front of the radiator come off. If you remove the entire front clip, getting the hood to fit will open a whole set of problems.
