Engine removal question
dpson
In reading the engine removal instructions in the Les Andrews book, he says to remove the intake and exhaust manifolds, the distributor, oil filler pipe, etc.
If I'm just doing an engine swap, can those items be left on the engine during removal and installation?
It seems to me they won't be in the way of anything if the radiator and headlight bar are removed.
when I pull / install motors, with or without transmission, I don't remove the headlight bar, as it's a pain to get off / on.
but you need a hoist / chain-fall that can lift vertically not a classic arm based engine hoist. a Gantry Crane works well.
I know of a kid that drop an A motor to a creeper and jacked the frame and body up, then rolled the motor out ! He couldn’t get it back in the same way, enlisted two brothers and dad to lift the motor back in. Dad wasn’t very happy and said you wouldn’t do that again.
Yep, remember pulling a 4 cyl. engine out of a 1958 MG using a 2x4, rope and another guy as crazy as I was. That was about 55 years ago. Nowadays I use the same method to remove the engine off an old lawnmower.
Is this what is called an "acquired skill", or???
I decided to remove the headlight bar, the idea of lifting the engine high enough to go over it didn't appeal to me, getting the mounting bolts out thru the fender brackets was a PIA, however the worst part was undoing the headlight wires which the previous owner had connected with crimped wire splices, had no choice but to cut the wires. Waiting for help to lift the hood off next. Most everything else is disconnected and out of the way.
I'm pulling the engine only, not the ******. Will keep you posted, thanks for the advice.
Good idea to remove the throttle linkage from rear of engine so that it does not get all bent up as they often do.
Many times it takes hours of messing around to get the linkage to work again!
Often the two 0.010 thick shims from upper flywheel cover bolts get lost in the process so good idea to check that they do not drop off and get lost.
Once I freed up the hinge pins, I removed the hood, in sections, to prevent damage. Then I replaced the hinge pins with WOOD Dowels, soaked in Linseed Oil. Linseed Oil comes from FLAX SEEDS. (NOT good for cookin' FOODS!)
Bill Tricky
To remove the hood you can remove the rear mount, the fold both sides up and rest them on the cowl. Move to stand in between the frame rails and grab both hood handles and lift it free. Slowly rotate yourself and remember to step over the front bumper and lower it onto a piece of carpet or cardboard. Well it works for me..........
Thanks, had my wife help lift the hood out (yes, we're still talking afterwards) as I hurt my back on Sunday cleaning out some heavy car stuff to go to the scrap yard. The only hold up was I had to tap the front of the hood with a rubber mallet as it was stuck in the radiator shell bracket. Getting the radiator out was also a PIA, couldn't get the lower mounting brackets out easily, the fender aprons kept them from being lifted up, so I had to drop the front splash apron and slide the bottom forward to get it out. If all goes the engine will be out tomorrow.
