Engine Rebuild
372dart
I got a motor with a bore of .060+. It might clean-up .100 over. If not .125 over. Do I spend the money to bore and seat the motor. I got a nice .010/.010 over crank for it. This block crack-free. Also thinking about big intake valves. What do guys think? Thanks. Rod
I'm not real sure what you are asking but if you are asking does it hurt anything to bore to 4.000, it is fine providing the water jackets are not excessively worn.
Is the block babbitt at .010 or are you going to scrape it to proper fitted size?
As far as the oversized intakes, that is fine too but remember that everything works best in combinations. Having the proper camshaft and free-flowing manifolds allows the valves to work more efficiently.
Thanks Brent. The Crank is done. just need to line-bore block. I'm gonna put a Bill Stipe IP 330 cam. Gonna use a A manifold bored for a B-carb.
