I have a question for the Model A owners about my engine...
I have a 1930 Fordor Town Sedan... All stock... Stock engine with a stock head, stock transmission, and a stock rear end... I am getting 11 miles per gallon...
Cylinder compression is 1-58, 2-56, 3-58, 4-56 lbs ... When I add oil to the top of the pistons and redo the compression test I get 1-60, 2-57.5, 3-60, 4-57 lbs... Not being an engine guru, could someone tell me if the rings are ok, or do I have something more serious going on here...
I have read several places here that the Town sedans should be getting around 15 miles per gallon, and I’m trying to see what I could do to get my mpg’s a little higher... I do use Ethanol free gas, it is well timed, the car runs well and burns No oil...
One more question... If I changed over to a high compression head (like a 5.5 to 1) would that increase the mpg or not?
Many thanks ahead of time...
