Joe/Ct
I have a 59AB with a oil filter cartridge installed. The filter that I used (recommended by the previous owner) is a NAPA Gold 1006. It was also recommended that I use Pennzoil 20W-50, which I have been doing. I have two questions:
1. We only drive about 1000 miles per year, but the oil is really dark when I change it and the filter each year. I believe that the oil is non-detergent (does not say HD), so what is causing the oil to be so dark?
2. I went to the store to purchase some new oil and found that the 20W-50 Pennzoil now has a note, which the previous containers did not have, stating " Active Cleansing Agents: Cleans out up to 40% of engine sludge in the first oil change". Does this mean that it is equivalent to HD (High Detergent)? Since the builder/previous owner suggested a non-detergent oil, should I change to another brand?
Comments/Recommendations?
Thanks in advance....Joe/Ct
