Michael_Velling
Compression is correct. Timingcover is from a Model b and this is the reason that the dimple doesent work.
Ordered a measurement and measured the tdc on 0.1 mm with this clock.
Adjusted the timing, checked the Compression, all valves new, all pistons new, all cylinders machined, all rod new..
But with a lot of turns the engine must suck fuel so that you see some fuel in the combusion chapter, or nit?
Michael Velling
Germany
www.velling.de
Michael Velling
Germany
www.velling.de
