Sometimes a particular noise will never be found. I have noted that loose wrist pins will quiet down by retarding the spark. Experiment at engine speeds just above an idle.While cruising along around 30 - 35, I hear a "ticking" noise from the engine. When I retard the spark lever just a couple of degrees, the noise goes away. What's wrong?
