Don
Finally got the 59 ab to idle after putting the orginal cam back in,fired up on first rev and set there and idled like it should.as i turned down idle i noticed a noise in engine ,dont think it is a valve, heaver than that,goes away at fast idle,took out the fp push rod ,no change,have a set of edmonmds heads and ck for valve clearence ,engine was rebujilt not long before i got it .vac is steady @about 16 in, oil pressure is unsteady @about 18 lbs at idle, about a 1 lb movement any ideas
