Engine Mount Bracket
Hi Guys, I have seen pictures in some workshops a bracket that attaches to the engine mount stand to hold the A engine side on - does anyone know how I can obtain one of these ? I saw one of these used by member Gary WA. Also can anyone help with specs and dimensions for a timber cradle (stand) if I pull the engine with sump and transmission and have something to drop it into. I would appreciate some help here. John Spragg Australia.
Do you have a copy of Bratton's catalog? On page 38 there is a side mount engine stand adapter. I have one and it works well. You have to have a 3 point or 4 point engine stand to use with the adapter. I think this is what you are referring to.
Rusty Nelson
I don't know if you have the ability to fabricate and weld but those special fixtures are easy to build and alot cheaper,built a frame spreader from the catalog picture in one afternoon.
Thanks rocket1, I will look into this as well - I wish someone had the dimensions or a drawing to assist here. The bought item is not cheap. John Spragg . Australia.
Just use your engine block to measure from. That's how I built mine.
If you don't have a welder or access to low priced steel, you might be better off to buy the ready made one. Steel has gone up a lot in the past few years.
I need to take new pictures of the adaptor I made, because I have notched the bottom of the pipe and heavy plate to access the center main bolt and nut. I cut at the center of the pipe diameter back about to the square pipes.
The adapters sold do not fit every engine stand. The adapter end tube may be too small.
