mantta
I noticed the last few years that I have a missfire that is unsteady after driving 30-40 miles. I have checked everything and today I noticed something I never thought of. My distributer has the aftermarket armored cable going to the ignition switch and it is not grounded to the cylinder head bolt like the original ones because it is much smaller in diameter. My distributer does not fit real tight in the head, it will wiggle a little but not anything of concern. So, I was thinking that the only ground the distributer has is to the loose connection to the head and it's drive shaft. I took a digital ohmmeter and read the resistance between the condensor ground and the engine and it read 4 ohms. Ahh, now the question, what is a good way to ground this cable or distributer?
Thanks!
Thanks!
