f balsiger
engine misses at all speeds. good compression which I think eliminates valves , no vacuum leaks (intake) tends to blubber. Almost goes away with full retard on timing. New modern point and condenser. Blue spark. what could it be?
I remember someone posting a coil tester from the 30's era, Brent maybe. Is there a modern equivalent to test a coil? How do you know if your coil is weak? Surely there's a way to easily test it??
I bench test coils w/an old distributor in the vise, a 6 or 12 volt battery, and a spark voltage tester similar to:
https://www.amazon.com/Deal】OriGlam...iagnostic/dp/B06X9RC3PF/?tag=atomicindus08-20
Not perfect but gives a good idea of the coils output.
