Bruce Compton Canada
My '49 has developed an occasional miss like the ignition is momentarily shut off and I suspect something in the overdrive wiring, or relay, or kick-down switch, or solenoid. Anyone else experienced this??
I've had one in a 53. Worked great.
There is a wire from the kickdown switch (under the gas pedal) that goes to the coil and shorts it out to kill the engine for an instant when the kickdown is activated. Any problem with that circuit or that switch can cause this sort of problem.
Since the accelerator has to be floored to activate this switch, the engine would be at full power just as the overdrive is trying to change, which is not a good situation. Got it?
