Working with a new A owner on a car that has been stored for 30+ years.
Engine was rebuilt 30 years ago, sleeved to std. bore, one piece guides, adjustable lifters, new babbitt, pistons, etc.
Doesn’t appear to have more than a couple of hours run time.
Pronounced knock when running, increases with RPM.
Isolating knock to bottom end, we removed pan.
What was found, side clearance on rods was .020” +.
Further inspection found bearing clearance to be spot on at .0015”, however, the rod journal width measure 1.632” (1.620” spec) wide.
Crank thrust measures .004”
So, the question, can rod babbitt be pored and machined +.010 wider than stock, any shop suggestions?
Or do I need to just replace the crankshaft?
New owner has budget concerns, so thoughts on best avenue to solve this issue.
Thanks
ken
Thanks
ken
