roddyb34
Its not the old wheres it coming from question ,,,i know it's #3 big end ,,its not to loud at the moment ,,we have had the sump off ,,the bottom end has been rebuilt at some time a long time ago but car wasnt used much but unknown build quality ,,there is stamps on the crank and block indicating 30 and 20 thou ,,the offending rod has no shims left ,if i drop the sump again and the rod cap then get journal measured correctly is it possible to get one recoed rod ,,? and install it ,,it will be head off too i realise,but would like to keep it going a bit longer ,,,
