I have a 1940 Deluxe which would have been made in Canada then shipped to Australia, the ident numbers stamped on the body are 01A-73405, however I am fairly sure the engine has been changed way back in it's history.
The number stamped on the block is *2C3389F* and there is an 81 cast on the block just above the right side water pump. In addition to this the heads have 81T cast in the middle of the top face.
The heads of the genuine engine should have "Made in Canada" cast on them, so I assume it is now fitted with an American engine.
Could someone tell me what vintage this engine really is?
Rod.
Rod.
