Here is what the engine is in, I have removed the dynamo that was (dynamo) tore down for scrap. The engine at this time has no oil or water in it so I am hoping the block is not cracked. I have filled the cyl with Kroil and let it sit for a week and today I sprayed a white lithium grease into the cyl and spun the engine with out the plugs. Seems to blow a lot of compression out the plug holes. It has spark at the points and the coil will snap at me, my problem is to get it to roll over a little faster just seems a bit slow. tomorrow I will add oil and maybe put 12 volts to it for a faster spin.
