I opened my engine gasket set and sorted through the gaskets. This is the first engine I have assembled. All the regular gaskets I know where they are used. However there are a couple of round gaskets I don't know where they are used. I have posted a picture of the gaskets below. The upper two cork gaskets I believe are used for ends of the oil return pipe. I do not know where the two lower gaskets are used. Can someone that has done an engine, please identify the usage of the lower two gaskets. Maybe it is obvious where they are used when I get to where they go, but not now. The larger gasket measures 2 1/8" OD and the smaller one measures 1" OD. They are both made of regular gasket material. Thanks for any help
Sorry I had oldtimers disease and forgot the picture.
