Engine Fan Repair
Bob Grieb
I have a question about the feasability of repairing the engine fan. In cleaning parts removed from the old engine I found that the fan had corrosion on the inside surface of one of the blades. After removing the rust I found that the blade itself is hollow. I thought of repairing it with JB Weld but I have some concern about balance (The damaged area is about 1 '' X 1/4 ''). Not being familiar with the Model A engine I am wondering if balance would be a significant concern.
Thanks in advance for your thoughts/help
Bob
Don't even think about it. Replace it with one of the aluminum ones available from the vendors. Reason: it could separate at any time, taking out the radiator, hood sides, you or a loved one if standing nearby IF it decides to "blow" apart. Do a search for other people's experiences and photos.
I'm sure others will chime in on your question.
Paul in CT
Thanks for the input. I was concerned about balance and never considered the safety issues. I really appreciate the advice and I will buy the new fan.
I am very thankfull for the help reveived
Bob
This is what it will look like if you keep running it. The other
piece will be in your hood or radiator.
