engine distrbutor shaft corrosion
KEN2939
replacing the dist. shaft rusted. can I clean the engine dist shaft port with a wire brush, and will debris fall into the engine pan or could I be causing a problem, any suggestions??
Hey Ken,
After cleaning up your present rusted situation, prevent recurrence by covering dist shaft with lube that won't come off easily. I use never seize with success for years.
Try a vacuum cleaner hose sucking at the lower end of the hole while you clean it. As a belt and braces measure, you might put a rag under that again.
The late distributors have a machined relief to act as a vent so moisture does not accumulate in the shaft bore of the engine and head.
